loading
ice dam quick fix ?
Quack if dice mix ?
iceng3 years ago
If you are 50 then this question implies ;
  1. You own your home or are helping someone who does !
  2. Winters heat and thaw is building an ice dam under your roof eave
  3. Your desire to Quick fix is to limit costly damage.
  4. A hair dryer has never been really successful at removing an ice dam
  5. A heat tape placed on a section of roof can increase the thaw time and start to decrease the ice dam
  6. A covered heat blanket can also help but is a dangerous way to go.
  7. If your days are sunny placing a black tarp on the roof will also assist in melting the dam.
  8. Best Answer if this hits you below the roof, this is your way to reward those who helped you most.
  9. In the attic run a fan to circulate air to the eaves.
  10. This comes from This Old House "Fill the leg of discarded pair of panty hose with a calcium chloride ice
    melter. Lay the hose onto the roof so it crosses the ice dam and
    overhangs the gutter. If necessary, use a long-handled garden rake or
    hoe to push it into position.
    The calcium chloride will eventually melt through the snow and ice and
    create a channel for water to flow down into the gutters or off the
    roof"
  11. http://www.thisoldhouse.com/toh/article/0,,1131314...
iceng iceng3 years ago
12. Don't Use Salt, the damage salt will do is more then the dam per
This Old House
petercd iceng3 years ago
salt will damage the plants, depends on their value I guess, compared to the damage the house will sustain.
Vyger3 years ago
Tell the neighbor kids you found some old gold coins burried in the ice.
petercd3 years ago
salt
rickharris3 years ago
is that Ice, damn quick fix
or Ice dam, quick fix.
or Ice dam, quick, fix.
or Ice damn quick - fix.
it makes a difference.
Why do I think we are not going to get an answer.
verence3 years ago
Fix an ice dam quickly? Use dry ice or liquid nitrogen!
Vyger3 years ago
On rivers they use high explosives, dynimite.
Kiteman3 years ago
A bit more detail would help a lot...
