3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
if I laser etched a bar code on to a piece of plastic...
... say a credit card or semi translucent acrylic, would it still be scannable?
May 23, 2009. 9:24 AMethosrot says:
It would have to be fairly accurate, and probably a white material (that the laser will make dark spots on). This is due to the way laser scanners work. They're fairly precise instruments so the barcodes have to be perfectly spaced. The only way this is really feasible is if you have a laser etching machine. Good Luck!
May 23, 2009. 9:50 AMlemonie says:
Using a sharp marker pen & a ruler would probably work as well. L
May 23, 2009. 11:55 AMfrollard says:
I've tried and tried to hand draw barcodes and they never seem to work - the tolerances are just too tight. Laser etched should work so long as the reader 'sees' the white areas and 'doesnt see' the dark areas. (same applies to reflectivity as plain white paper, but etching plastic would be 'white' where you etch, and black where its transparent)
May 23, 2009. 12:53 PMlemonie says:
Depends upon the reader to some extent, but yes the tolerances aren't too forgiving. Then again laser printers work fairly well L
May 23, 2009. 2:16 PMfrollard says:
virtually any printer - hence why a laser etch would be ...perfect :D
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
