loading
in ground dog fence troubleshooting,
I fixed a break a week ago, now both dog collars are not registering. the fence alarm is not sounding, so I replaced both batteries in the dogs collars, still nothing, got any ideas?
Re-design5 years ago
I believe you can use a short piece of wire in place of the yard wire to test the unit. Do that and if you get sound the fault is in your yard wire. If you don't then your transmitter probably is bad since it would be very strange for both receivers to go bad at one time. Unless you got a bad batch of batteries or you put them in backwards. That can happen, I know from experience.
+1
btw, "youngerboo", post your comments as a "reply", otherwise the member you're replying to won't know you left a message.
youngerboo (author)  canucksgirl5 years ago
ok, thanks... I'm new at this :)
You're welcome. I just wanted to make sure your comments get to the right person.
youngerboo (author)  Re-design5 years ago
Thanks I'll try that.
youngerboo (author) 5 years ago
yes, I did. I think it is a collar issue.
Did you check the repaired area with a voltmeter to ensure power is getting through?
+1
