loading
integrate signals?
hi i have square wave start 5 then 0  picture 1with variable duty cycle i want to convert it to the signal in picture2i did integration in picture 3 but didnt invert the signal .
Picture of integrate signals?
you want to convert a square wave to a triangle wave.
RC filter
This will change with frequency on the output put a resistor to a capacitor that goes to ground where the cap and resistor meet you get a triangle wave.
Joe
britich (author)  Josehf Murchison3 years ago
yes but i need it to be zero on negative square cycle and half triangle at positive edge i did like you said but i need to make it zero at negative square cycle i thought i can do it using scr ?
That or a diode on the output then it only goes 0 to + or 0 to - depending on the direction of your diode.
Joe
thanks Joe
What are you trying to do ?
britich (author)  steveastrouk3 years ago
generate the signal 2 from signal 1
yes, I can see that, but what for? like Joe says, an RC filter will do that.
