is it possible to use a low voltage controller at higher voltage?
i want to make a isolated switching power supply intended to drop and convert 220VAC to 12VDC, but the only available controllers in my area can only handle 100VDC at maximum. is there a way where i can use those switching controllers at 220VAC?
Jun 24, 2012. 9:30 AMsteveastrouk says:
Not readily. The whole front end is designed for 100V operation.
MOST modern switchers though are designed to be universal input.
Jun 24, 2012. 11:44 PMsteveastrouk says:
How many VA ?
Where are you in the world anyway ?
Jun 25, 2012. 6:58 AMsteveastrouk says:
Get an ordinary transformer - something like 20VA will do, with a tapped or split primary. FORGET the secondary, but you need a transformer of at least 15VA.
Connect the supply input to the 230 V pins, connect the 110 V PSU from the 110 V pin and the neutral connection.
Here's a sketch
Jun 25, 2012. 8:22 AMsteveastrouk says:
Are you sure you can't get universal input supplies ?
I wouldn't mess with the internals of a switcher.
Jun 28, 2012. 3:54 AMsteveastrouk says:
You're stuck then. Though, like I said, I haven't seen anything BUT univeral inputs for years.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
