is the ps2 connected mouse's microcontroller programmable ?
and if it's true is it programmable?
answers
Answer it!
Now they are trying to phase out the PS-2 altogether. At least some MB manufactures are. And serial and parallel are long gone all in favor of the USB.
So while the controller in the mouse is not changeable the port itself can be used for other things. But in order to use it you would need to get the exact pin specs and be able to program whatever it is you would want to add in. BY the way, originally the keyboard port was controlled by a separate chip on the motherboard. There were times when that chip would go bad but the board would continue to work fine. When that happened then you had to get an add on card to get around it so you could keep using the system.
Steve
