is there an easy way to make a waterproof phone case for a slider phone?
 the phone is specifically a samsung gravity 2.
Burf7 years ago
When I go fishing, I always stick mine in a zip-lock sandwich bag and I can use the phone without removing it from the bag.  Making something that allows you to use all the buttons without removing the phone is going to be tricky
lemonie Burf7 years ago
I couldn't better that.
L
Ditto. Double-bagging may be worthwhile. I wouldn't bother with duct tape; if you need a tighter seal than that, I'd suggest finding someone with a vacuum-sealer and heat-welding the bag(s).
NatureBoom21 (author)  Burf7 years ago
 hmm...... would using 2 bags and duct tape make it safer?
Sure, but it might make it a little difficult to see and use the buttons.  I would think that one should work fine, although sealing it shut with the duct tape will add a little extra security to keep the bag from opening accidentally.
 Something along these lines will be extremely waterproof....
www.diyphotography.net/diy_the_cheap_yet_shamefull_underwater_housing
NatureBoom21 (author)  FriendOfHumanity7 years ago
i use 2 bags, just in case. im happily texting in the shower now :)
