lcd stand or bracket?
Hi have an LCD and finding a mount seems to be almost impossible. To attach a mount it first need to be recessed into the screen.
The VESA dimensions are 200mm X 100mm. Does any one have any ideas as to as to how I can fix this monitor to the wall.
The monitor is a Samsumg 2494HS
Thanks
Burf6 years ago
Google "VESA mount, 100mm x 200mm" You'll get quite a few hits.
frollard6 years ago
If I recall correctly, a standard 100x200 mount should screw on to the back after you pop the cover plate - and that bracket will clamp onto the wall plate. What exactly is the problem?
If a standard universal mount is too tall to fit in the cavity, you have to find one that fits, probably a 100x100 that has extension arms like
http://www.amazon.com/VideoSecu-Adapter-Bracket-Extender-W39/dp/B0032HHXVM/ref=sr_1_10?ie=UTF8&qid=1302081123&sr=8-10
You can also make your own out of a piece of aluminum or steel -- an adapter that has its own 100x100 holes to mount a standard monitor mount, and itself attaches to the 200x100 holes on the monitor.
