little gem mk2 amp question?
Hello, i going to make a little gem mk2 amp.But i see 2 layout and they are a bit diffirent ....I dont know what version is correct or both are correct ??
And i want to  add a LED to know if the amp is on or off, where should i place it ??? I use a 12v 300mA adapter as power cource.
Thanks!
http://i247.photobucket.com/albums/gg132/chipmapple/upgem2layout.png
http://i247.photobucket.com/albums/gg132/chipmapple/upgem2cir.png
Picture of little gem mk2 amp question?
gmoon6 years ago
A schematic is conceptual--usually concepts like GND and V+ connect by implication, but not explicitly (as is GND is this case). Often (not in this schematic) the IC V+ power supply pins aren't included all, because it's assumed.
On the other hand, a layout or wiring diagram shows the actual physical connections of parts.
Schematics can conveniently avoid considerations such as oscillation from traces or components that should not be in close proximity; layouts cannot.
But schematics are often easier to understand, because the circuits is stripped down to its minimum. If I'm looking to understand a how a circuit works, I want to see the schematic. If I just want to build it, then the layout is preferable.
An LED indicator can be wired directly to the board by placing the LED and a current-limiting resistor (1K? depends on the LED) between a GND and a 9V trace. Or else use a DPDT switch--one pole for the board power, the second pole switches the LED/resistor to the power.
Re-design6 years ago
There are several ways this amp can be wired and still work. If you're not sure if a diagram is correct then breadboard it before you make and wire a pc board.
As for the led, wire it so that when you turn on the switch if complete the circuit for the led.  You will have to make arrangements for the correct voltage.
