loading
macbook pro wont power up?
Troy_14 years ago
MacBook Pro
I found this in the MacBook Pro user guide (15'', late 2011 model)
"If your MacBook Pro doesn’t turn on or start up
Try the following suggestions in order until your computer turns on:
- Make sure the power adapter is plugged into the computer and into a functioning
power outlet. Be sure to use the 85W MagSafe Power Adapter that came with your
MacBook Pro. If the power adapter stops charging and you don’t see the indicator
light on the MagSafe connector turn on when you plug in the power cord, try
unplugging and replugging the power cord to reseat it, or try another power outlet.
- Check whether the battery needs to be recharged. Press the small button on the left
side of your computer. You should see one to eight lights indicating the battery’s
level of charge. If a single indicator light is on, connect your power adapter to
recharge. For more information about battery indicator lights, see page 54.Chapter 4   Problem, Meet Solution 53
- If the problem persists, close all open documents and quit all applications. Return
the computer to its factory settings (while still preserving your files) by pressing
the left Shift key, left Option (alt) key, left Control key, and the power (®) button
simultaneously for five seconds until the computer restarts.
-If you recently installed additional memory, make sure that it is correctly installed and
is compatible with your computer. See whether removing and reinstalling the old
memory allows the computer to start up (see page 44).
- Press the power (®) button and immediately hold down the Command (x), Option,
P, and R keys simultaneously until you hear the startup sound a second time to reset
the parameter RAM (PRAM).
- If you still can’t start up your MacBook Pro, see “Learning More, Service, and Support”
on page 64 for information about contacting Apple for service."
If this doesn't help, here is the link
http://support.apple.com/manuals/#macbookpro
bwrussell5 years ago
Gonna have to provide more info.
