minecraft crashed please tell me why
this is the report:
Mods loaded: 3
ModLoader 1.2.3
mod_ModLoaderMp 1.2.3v2
mod_PortalGun 1.2.3v1
      Minecraft has crashed!
Minecraft has stopped running because it encountered a problem.
--- BEGIN ERROR REPORT ac9bad2f --------
Generated 3/18/12 8:16 AM
Minecraft: Minecraft 1.2.3
OS: Windows XP (x86) version 5.1
Java: 1.7.0_04-ea, Oracle Corporation
VM: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
LWJGL: 2.4.2
OpenGL: Intel 845G version 1.3.0 - Build 4.14.10.4342, Intel
java.lang.NoClassDefFoundError: forge/ITextureProvider
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.access$100(Unknown Source)
at java.net.URLClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at mod_PortalGun.initModPart(mod_PortalGun.java:285)
at mod_PortalGun.initModParts(mod_PortalGun.java:256)
at mod_PortalGun.load(mod_PortalGun.java:137)
at ModLoader.init(ModLoader.java:890)
at ModLoader.addAllRenderers(ModLoader.java:186)
at aho.<init>(aho.java:79)
at aho.<clinit>(aho.java:9)
at net.minecraft.client.Minecraft.a(SourceFile:267)
at net.minecraft.client.Minecraft.run(SourceFile:650)
at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.ClassNotFoundException: forge.ITextureProvider
... 21 more
--- END ERROR REPORT 79ffcb55 ----------
SeraphJacob5 years ago
Portal Gun mod is either an older version not compatible with the most recent Minecraft and ModLoader release (V1.2.3) Or you haven't installed the Portal Gun mod correctly
Try installing it by opening the folder .minecraft/bin, the opening minecraft.jar in WinRar. Then copy all the files in the Portal Gun zip into the minecraft.jar and make sure you delete the META_INF folder in there, then try again
pony2 (author)  SeraphJacob5 years ago
its got instructions how to install it on the forums
you put it in the mods folder :D
lemonie5 years ago
Why aren't you asking this question on a Minecraft website?
L
pony2 (author)  lemonie5 years ago
beacase
lemonie pony25 years ago
no because
That error report tells you nothing. Chances are it was a random error from one of the mods your running. Is this a recurring problem or has it only happened once?
pony2 (author)  mpilchfamily5 years ago
only once but i havent tried minecraft since
pony2 (author)  pony25 years ago
never mind i just played and it didnt work
frollard pony25 years ago
unselect/remove all the mods, and replace them one at a time until you find what actually crashes.
