loading
my dell charger is not working ....?
i have a dell lattitude c840 ..its charger suddenly stoped workin ...is there any other go or should i hav to buy a dell charger...is there a cheaper idea?
use deoderant i can smell you all the way over here!
Even more likely, the wires have broken between the supply and the plug.
seandogue7 years ago
Are you sure the charger isn't working? If your batteries are worn out thy won't charge properly. Does it have the OUTPUT voltage and current rating stamped onto the body? Or alternatively, are you in possession of the user's manual for the laptop, and does it specify the operating voltage/current, or voltage/power? If so, it's quite possible that it can be replaced with a generic solution. If the batteries have reached or are approaching their end-of-life, then replace the batteries.
