my idea how to make Edison bulb more efficient?
by coating the bulb with a something that reflects infrared, but lets visible light through. this coating will reflect the infrared radiation (heat) back to the filament, heating it up much more. [update: i found there is a substance that can do this. its called Indium tin oxide]
another thing is instead of argon gas, have a complete vacuum. and a thick glass bulb.
I theorize the inside filament will heat up much more that normal, and the glass will stay cool to the touch. another good thing is the light will be higher in color temperature, because some of the red light may be unable to escape, raising the color temperature. the thick glass will resist breaking.
obtaining a vacuum is easy, but the special coating, is there anything in the world that exists? and will it do all the things stated above?
[update: again, i found there is a substance that can do this. its called Indium tin oxide]
12
answers
Answer it!
Steve
It's an interesting insight. If you can figure out how to make it work...
But given how much power one saves by switching from incandescent to other technologies -- and not wasting power on producing heat in the first place -- I suspect that this is not going to be economically competitive.
Steve
As Ork says, read about Halogen lamps - they really ARE clever.
Steve
