loading
my laptop wont work the battery needs charging or replacing and it wont charge please help me guys? (closed)
its a pakardbell dont know the model
NachoMahma7 years ago
.  If the battery is more than 2-3 years old, it probably needs to be replaced. Check to make sure that the charger is working before purchasing a new battery.
lemonie7 years ago
Turn your Packard Bell upside down, it may have the model number underneath.
L
pilotwebb (author)  lemonie7 years ago
the model is mit-rhea-c
jeff-o7 years ago
Did it stop working suddenly, or has your laptop's battery run-time been slowly decreasing for a while?
If it happened suddenly, it could be a broken charger, broken charger cable, or broken DC jack on the laptop.
If the laptop runs fine with the charger plugged in, but the battery won't hold a charge, then it's probably the battery.
pilotwebb (author)  jeff-o7 years ago
i cant remember but i think i finished on it then when i went on it again it wouldnt turn on
Re-design7 years ago
Does the computer run when the charger is hooked up and turned on?  If yes then it's probably your battery and not your charger.  If the charger is good and the battery still won't take a charge then it almost definitely is you battery.
LoneWolf7 years ago
THe cord that connects your computer to the outlet might have burned out, mine did about three weeks ago and it was having the same problems yours is.
