my soldering iron isnt working properly! PLZ HELP ?
23
answers
Answer it!
I have always used this method and I have tips that are many years old (10+) but I also do not use my iron for anything but soldering (its amazing what people use these for...melting plastic etc.).
Upkeep on your tools and proper use will make them last many years. I have a Weller station which is 15+ years old and a Hakko 936 that I bought about 2 years ago. Both of which I had no tip issues with.
As an electronics hobbist (36 years) and Tech.advisor for several companies;I personally have observed that the best care for a tip is,NO abrasives or acids.As for the discolorisation,try rubbing alcohol 70%<.All it might be is packing oils burning off.
I hope this helps.
Get a razor blade and scrape the crud off of the tip...It shuld do the trick..
Regarding the legend of the special tip "coating" that others have warned you not to sand away, let me humbly tell you the story of copper soldering iron tips that come with no factory coating, because they're homemade!
http://www.instructables.com/id/Soldering-iron-tips-from-6-AWG-copper-wire/
(a shameless plug for one of my own instructables)
I think soldering iron tips being slowly consumed by the heat they live and work in is just a sad fact of life.
Sand the tip. Re-tin it. This is the way.
What you have there is a solid thick oxide layer that will act as an insulator and slow the heat transfer process. What you need is to clean the tip and keep it tinned with a bit of solder every time you finish using it. There are small tins of compressed solder powder that you can get with flux mixed in that act as tip cleaners and tinners in one. Massively handy and invaluable in any solderer's tool kit. Take a look around your local electronics store to find one.
Here's an example from Maplin in the UK: http://www.maplin.co.uk/module.aspx?moduleno=3929
Hope that helps.
