my tv is clicking but wont turn on, why?
Oct 11, 2012. 2:28 AMcanucksgirl says:
It could be a number of things... knowing the type of TV you have, plus the make and model would also help. ;-)
In the mean time, if its a Samsung LCD, there is a known issue with capacitors failing after a few years. It won't turn on, but it'll make a clicking sound. You can read about how to fix the problem on this webpage... thankfully the fix is fast and cheap.
Oct 10, 2012. 6:53 PMRe-design says:
You might try resetting the tv. Look in the manual for how to do that. Fixed mine that way once but with a different problem.
Oct 10, 2012. 2:40 PMfrollard says:
probably bad capacitors.
If you don't know what that means, then you should probably have a qualified repair tech look at your tv, or send it in to retailer/manufacturer for warranty repair.
If you know what that means - then you know with a soldering iron and some online ordering you can get replacement parts for just a few bucks.
http://www.youtube.com/watch?v=72sJ5Infuu0
http://www.youtube.com/watch?v=Ytw57212X2o
Oct 10, 2012. 3:05 PM5hockwave2 says:
i love capacitors
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
