loading
need suggest low voltage power amp ic?
Hello . i need some suggest on choosing power amp ic.My project requirements are:
-Low voltage : 9-12v (can be run with a 9v battery)
-Good sound quality
-Output power : ~2w
-Small size
-Easy to find
Thanks !
Sorry for may bad English!
You'd be better with the other IC I recommended in your last post, the LM 4951, which will give you a couple of watts out of the packet, with no extra bits. Otherwise the TDA2003's not a bad part, but you need a few extra components.
Steve
login721 (author)  steveastrouk5 years ago
Thanks. but the problem is i cant get the LM4951 in my country .The TDA2003 is good but its will drain battery very fast .
So turn the volume down !!!!!
2W, your stated requirement is going to drain a 9V battery in short order WHATever.
Steve
