need to change belt on small 3kg philips D153 tumble dryer (FRONT LOADER)?how do i get into it
Be very careful about the sharp edges inside ! I have a two inch scar across the back of  my hand from removing a bearing inside a machine, and banging my hand on the access cover....
Kiteman7 years ago
Most front-loaders have a removable back panel.  Unscrew, and you should be confronted with the pulleys and belt.
If you're unlucky, the panel that needs removing is the top panel, and you have to reach down the back of the box to swap the belt.  Be prepared to say goodbye to the skin off your knuckles...
Try here. It may be similar.
https://www.instructables.com/id/How_To_Replace_a_Dryer_Belt_on_Whirlpool_Models/
The top should have a couple of clips in the front if it's anything like mine.
A flat head screwdriver should pop the top.
