pls read details
i want a bulb/led to light up with an intensity dependent upon the amount of light that hits the analogue light sensor...do i really need arduino or any programming? , or can i just connect the battery ,the light sensor and the bulb in a simple circuit??
bwrussell4 years ago
It's projects like this that make me wish the Digispark was out now. Simple, as long as you can write basic code, and cheap.
£1.80 picaxe 08m will do this easily in a few lines of basic code! the pwm for the output is the hardest part.
Personally I would put multiple leds on separate outputs to vary the light level then it becomes easy
www.picaxe.com
I think a microcontroller is kind of overkill when all you need is a single gain connecting an analog in to an analog out.
Especially in the case when the gain you want is exactly 1.
Any of you kids ever heard of a op-amp wired as a voltage follower?
http://en.wikipedia.org/wiki/Operational_amplifier_applications#Voltage_follower_.28Unity_Buffer_Amplifier.29
A single transistor wired as an emitter follower?
http://en.wikipedia.org/wiki/Emitter_follower
Anyone? Anyone? Bueller?
+1
Also depends on the type of 'led bulb'. Anything closing on a watt will need a driver circuit, and a lot of driver circuits will try to compensate for any dimming you do outside of that circuit, burning themselves out.
If just a simple single led strand on a dc supply + resistor, your emitter follower is the perfect solution.
rickharris4 years ago
Simple? Probably not although that depends on your experience.
i would say the easiest approach is the micro controller but that is going to be software complicated,
A comparator will do something such as you want look at the data sheet for the 741 for example.
