loading
power car headlamp with LED as home decoration lamp?
Hello, everyone
I have this Audi A4 Lamp with LED DRL, I want to power the LED up at home as decoration.Opened the headlamp housing, and trace the wire, I found the led strip has 4 wires, and I don't know which is (+) which is (-), I did some internet search of 4 pin led strip, and most of the info was RGB led. I don't believe this Audi LED DRL has RGB. tried (+ + - -) (+ - - +) (- + + -) with no luck.
any advice to power the LED up at home?
Thank you.
Picture of power car headlamp with LED as home decoration lamp?
Kiteman3 years ago
The LEDs will be designed to tun on 12V - what size battery did you test with?
Kiteman Kiteman3 years ago
(*run* on 12V)
VanWeeD (author)  Kiteman3 years ago
Thank you, Kiteman
I did, but don't know which wire is which, I took apart the LED, hope this will help for wiring.
Thanks
It looks like that is set up as 2 series strings of LEDs. Probably broken down to 7 LEDs per string. As the flat flex cable indicates the 2 center contacts are probably your positive with the outer being negative.
Or they could be set up as 4 seprate strings of LEDs in series in which cases the entire flat flex cable is the positive leads and there is a common ground somewhere.
In Either case you should be able to take a 9V battery and start touching your leads to the battery terminal till you get things to light. If nothing lights off those 4 connections then look for a common ground somewhere else.
If this is metal I bet that is your negative.
rickharris3 years ago
A manual for the car should give you a wiring diagram - a good start. Your library may be able to help with the manual.
