quick two wires diagram,4 wires in one blk,green,white,red,other red, blk, cell phone?what goes together?
4 wires too 2 wires how do you put them together Blk,red,green,white the other blk  ,red to get a connection for cell phone charger have to use what i have right now
AbinP11 year ago
how to connect four wires in a usb charger to a 9v portable charger?
whacked2 years ago
I want to connect a usb in port to a solar trickle charger the charger has a white and red wire and the usb in has a black red white and green wrapped in foil surrounded by copper wire how do I connect these I am trying to make a charger that will charge usb powered devices by solar
KevinR42 years ago
Jlp.gold your answer wrong it's a car charger everyone else's thank you but I bought a new one
jlp.gold2 years ago
How dumb ull are! Its an mp3 player for a car, fitting into the lighter socket.
Anyways the answer is that u only connect the black from usb to green from player, red to the red and the green and white wires left from usb dont get connected to anything. #BOOM
KevinR42 years ago
hello does anyone knows where the red n green cord connects to thank you
KevinR42 years ago
You know, {black, red, green, white} is a color combination I have seen inside a cut-open USB cable. Maybe that's what you've got there? It's kinda hard to tell what you're talking/writing about, but I am guessing you want to connect a cell phone charger to a cut-open USB cable?
Anyway, for that USB cable, red is +5 V, and black is ground (0 V).  The green and white are the complimentary data lines D+ and D-, respectively.
See also, the pinouts.ru writeup on USB:
http://pinouts.ru/Slots/USB_pinout.shtml
Assuming your phone charger cable, with its red and black wires, actually wants +5V on the red wire, and 0 on the black one.  Then it's red-to-red and black-to-black, and the green and white left unconnected. Or something like that...
It looks like there are some similar 'ibles in the related panel.
You should look at those, and see if perhaps the wires in those pictures look like the wires you are desiring to connect.
CameronSS5 years ago
You need to tell us how much time is remaining on the bomb before we can tell you which wire to cut. If it's more than ten seconds it won't be dramatic and you're out of luck.
Re-design5 years ago
You're outa luck! Any answer without knowing what you're trying to connect and what was connected is just guesswork.
You might think the blk and red connect to the other blk and red but you  have at least 50% chance of being wrong.  And being wrong means you probably will ruin your phone and or charger.
