rack and pinion?
hello everyone
im trying to design a minature working slat drive system taken from an airbusA320
the problem i have is locating a curved rack
does anyone know where i might find one or the best way to make one
i can get the pinion and motor etc its just the track
ive included a diagram so you can see how it all works
its driving me mad!!
Picture of rack and pinion?
nicelly5 years ago
Occhiali low cost neri avvantaggiare alcuni dollari eventualmente scoraggiare l'Ultraviolet. In verità sulla questione, il sapore davvero difficile aiutare apportano un anti-UV prestazioni nel vostro obiettivo zoom, e
ray ban come prezzi di gran lunga non sono decisamente troppo sostanziale, quindi adatto a basso costo tende da sole hanno in più la funzionalità di molti di vietare il danneggiamento leggero.
Bend one ! You can get plastic rack that you could form around the arm, or you could literally bend it with a three roll bender - though I'd bend a pair of racks mounted tooth to tooth - keep the one with the teeth on the outside of the curve. The other is sacrificial.
Or get one laser cut, if you can get away with a wooden or plastic one.
Or get one wire-cut, ifyou want a precision metal job.
madaboutjets (author)  steveastrouk5 years ago
ultimately id like to cut the teeth in my self directly onto the arm as its a precision mechansim i cant afford it failing or snagging
how difficult is it to make a rack?
Rack cutting is a specialist job, usually done industrially by planing the teeth. For small quantities, wire-edm is the only way to do this.
Steve
I think that method hadn't practical to me ad I don't have the equipment
I'm experimenting with belts from an old printer and trying that out !
+1
If you have a Tech Shop close to you, a laser cutter could get you whatever bend and teeth you need.
Re-design5 years ago
Get a toothed drive belt and gear then glue the belt to a wood/plastic/metal arm that's cut to the correct shape. You can get them online at surplus parts sites.
madaboutjets (author)  Re-design5 years ago
i like that idea
so just a case of epoxying a section onto the arm and hay presto
And yet you say
....precision mechansim i cant afford it failing or snagging......
Hmm.
+1
