receive this error code when verifying ColorCrossFadeRGBLED sketch ?
When I try to verify this code this line gets high lighted in the code it self:
bluVal = calculateVal(stepB, bluVal, i);
On the bottom of the sketch I get the fallowing error message:
'stepB' was not declared in this scope
arduino-builder/arduino-builder -compile -core-api-version 10611 -build-path /tmp/187362358 -hardware arduino-builder/hardware -hardware arduino-builder/packages/cores -tools arduino-builder/tools -tools arduino-builder/packages/tools -built-in-libraries arduino-builder/latest -libraries /tmp/768638835/pinned -libraries /tmp/768638835/custom -fqbn arduino:avr:uno -build-cache /tmp -verbose=false /tmp/768638835/ColorCrossFadingRGBLED
/tmp/768638835/ColorCrossFadingRGBLED/ColorCrossFadingRGBLED.ino: In function 'void crossFade(int*)':
/tmp/768638835/ColorCrossFadingRGBLED/ColorCrossFadingRGBLED.ino:114:28: error: 'stepB' was not declared in this scope
exit status 1
bekathwia4 months ago
When you get any error that says "not declared in this scope," it means it's missing a variable declaration. For me the sketch compiles just fine, and int stepB is declared just a few lines above the part that's throwing your error (line 191). Are you sure you copied the whole sketch, and didn't accidentally delete part of it?
Mark Richardson (author)  bekathwia4 months ago
Thank you for your help your answer made me go back and recheck for typing mistakes and I found two. these codes/programs are very sensitive. I had one letter upper case and one word misspelled. I fixed them and it worked fine. I also figured out how to copy / paste from the autodesk so no more manually typing in the code. THANKS again.....
