3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
rectify electricity before transformer?
can you rectify the US mains (120vac, 60hz) as it, and used the pulsed dc to feed into a transformer and get a dc voltage out of the transformer? I'm asking this because it would be much much more efficient for high current situations. Here's my specific situation:
I want to build a capacitive spot welder and a capacitive discharge cutter in an all in one device. To charge the enormous capacitor rapidly (1.5 farads in my case), I need a very high current power supply. I'm using a modified microwave transformer that was rated at 1kw, and it is now modified so that it outputs 12 volts AC at around 80 amps (probably less because of losses). This must be rectified to charge the capacitor.
Assuming a perfect transformer (for arguement), it would have:
120volt, 8.34 amp input
12volt, 83.34 amp output
the following is with full bridge rectifiers, assumed voltage drop: 1.4v
If the power was rectified before the primary, the loss on the bridge rectifier would be: 11.67 watts
If the power was rectified after the secondary, the loss on the bridge rectifier would be: 116 watts
huge difference
so once again, the final question is: Does rectified input of a transformer = rectified output? Does the 120hz pulsed dc (as opposed 60hz ac) matter? Could this setup charge a capacitor?
1 answer
Nov 25, 2009. 5:41 PMmuttyfutty says:
Sorry!
I'm afraid transformers only work on AC.
Well, actually pulsed DC will work, but wont be as efficiant.
as to pure DC, then no chance.
Capaciters charge best on DC,
sorry I con't help you more!
mike
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
