remove windows password?
topunlocker8 years ago
Welcome to my blog http://pdf-to-wrod.blogspot.com , I am interested in password recovery. Besides, http://wiki.e107.org/?title=Bypass_Windows_XP_Password there is an article about how to reset windows password. It must be helpful for those who have been locked out of computer .Besides, there is a smart solution at http://sn.im/wpu , which can help you bypass windows passwords without knowing it. It never delete anything else but the unknown password
Yolandas6 years ago
Three common and safe methods to reset your lost Windows admin password Forgot Windows xp admin password? Don't worry!Let me show you how to recover it with three available solutions,widespread methods.Hope it can help you!By the way,I just want to say that Windows password is not security,people can use this tool to gain access whichever computer installed Windows 7/vista/xp/2008/2003/2000.If you want to know how to protect your windows admin password,you can find out answer here:
http://www.daossoft.com/blog/protect-your-windows-password-by-bios.html
Method 1
Use the built-in administrator account which you can logon without password in safe mode.It was built when you install your system and its password default as blank.Press ctrl+alt+delete twice in the welcome screen and you can see a classical logon dialog box,type administrator and press Enter.Or you can press F8 when you start/restart your computer to select start from safe mode.
Method 2
Use a password reset disk If you have created ever.Of course it must be created for your current password.You can find a prompt when you input a false password in the welcome screen.Clik it and follow the guide.
Method 3
If the two methods above cannot help you,you can find a recovery tool. As far as I know, there are many password tools on the network, but I have used is "Windows password rescuer professional" ,it is simple and safe that the average person will use it. It can soon reset the password in several minutes.Only four steps can help you reset the lost Windows password:
Step 1: Download Windows Password Rescuer and install it to another computer.
Step 2: Run it and burn it to a bootable CD/DVD or USB flash drive.Before this confirm that you have insert a CD/DVD or USB.
Step 3: BIOS setting:Setup your own computer boot from CD or USB.Press F2 or DELETE when you start/restart your PC to get into the BIOS SETUP list.
Use arrow keys to select boot manu,and use +/- key to move the CD/DVD or USB option to the first site.
Then inset the CD/DVD or USB you have just created. Press F10 to save and exit.
Step 4: Reset Windows password: Wait for a moment,it will display friendly operate window,and you can reset whichever password on it.More detailed instruction refer to this article:
http://www.daossoft.com/documents/how-to-reset-window-2000-xp-vista-win7-password.html
EmilyChang6 years ago
Forgot  Windows password? TRY TO reset it with a Windows password recovery tool. Use Windows Password Unlocker to create a Windows password reset disk with CD/DVD or USB flash drive.
Step 1: Download Windows Password Unlocker Professional from
Step 2: Create a password reset disk with the program in any accessible PC Step3: Insert the reset disk in your locked computer Step 4: Remove the forgotten password with the created password reset disk
The Windows Password Recovery can solve all your problem within a few minutes. Importantly, No need to call a technician, no need to re-install anything, and you certainly don’t need to reformat. it is a windows password recovery tool that also support win 7 & vista password recovery..
zhuismile7 years ago
1. Login to a computer that can link to Internet. Download windows Password key from http://www.lostwindowspassword.com and install it on that PC. Note that: there is a .ISO file. Burn the .ISO file to a CD or a USB flash drive. 2. Insert the newly created CD/USB drive to the locked computer. 3. Reboot the locked computer and press'F2'or'Delete'to enter your BIOS setup and then followed the process of instructions. Just a few steps, the old password was removed.
annyyu227 years ago
This sounds pretty interesting. We used a similar software at my tech support job a few years ago. Called  "Windows Password Key 8.0".
It works very prefect to regain your password .Also use boot CD/DVD.
I have download it from this website : http://www.lostwindowspassword.com
hecongyan7 years ago
I think the best way for you is to reset your windows password. The Windows password Key 8.0 can solve all your problem within a few minutes. Importantly,No need to call a technician, no need to re-install anything, and you certainly don't need to reformat.
it also allows you to reset windows password with with USB Flash Drive or Floppy Disk now!!
Free trial Windows Password Recovery Tool---Windows Password Unlocker is highly recommended
1.Download Windows Password Unlocker from Password Unlocker Official site
2.Decompress the Windows password unlocker and note that there is an .ISO image file. Burn the image file onto an blank CD with the burner freely supported by Password Unlocker.
3.Insert the newly created CD into the locked computer and re-boot it from the CD drive.
4.After launched the CD, a window pop up with all your account names(if you have several accounts) select one of the accounts that you have forgotten its password to reset it. Just one press, you have removed the password.
I recommend this tool Lazesoft Recover My Password. It has a graphic gui interface. It is very easy to use.
www.lazesoft.com/how-to-remove-windows-password.html
Fluth48 years ago
I have downloaded Windows Password Recovery Tool 2.0. it not only supports XP, 2000, and NT, I have personally tested it with Vista Home Premium and Ultimate. It works perfectly to reset any local user account to a blank password. I Wrote it to an old 128mb USB flash drive do this. Booting up and clearing a password takes a minute or two works like a charm.
You can get it from: http://www.windowspasswordsrecovery.com
Great!!!!  This tool is useful. it help me.
Thank you.
tannpopo8 years ago
Long time ago , I was confronted with the password problem. Finally , my friend Jane introduce the Windows password Reset.It helps me access windows. http://www.resetwindowspassword.com
cheater!!!
countable8 years ago
I concur: remove windows password for great justice.
lemonie8 years ago
Yes do it!
