loading
resonance wireless inductive coupling final year project (wireless handphone charger)
hi im doing wireless inductive coupling using square coils.Anyone can advise which equation to determine the inductance? i dont have a LCR meter :(
I have problems combining my full wave bridge rectifier and voltage regulator. Do i need impedance matching?
breadpig (author) 7 years ago
heres a pic of my square coils.im doing a wireless handphone charger over here.i've determined the inductance value.now im trying to use ADS to do simulation on the magnetic field radiation.Anyone did that before?
mathews7 years ago
Don't have a inductance meter? Make one.
An LRC circuit will have a specific resonance frequency (which you can measure with a counter and timer). So knowing C, R and F, you can calculate L.
What is the circuit you are trying to make? If you post a circuit diagram, the context might make it easier to help.
Better to ditch the R, and get a strong resonance. Too much R and the Q will be very low.
I found references to square coil formulae in the first hits on Google. If this is a final year project.
Imagine a world, oh, only 20 years ago when instruments like LCR meters were so hideously expensive people had to use other techniques (actually, often more precise); How did they do a simple measurement of inductance ?
Steve
you could experiment by making two basic coils as similar to eachother as possible and see how well they work, if they're functioning within a tolerable range a voltage regulator and circuit could be used to control the end output within a certain range of inputs coming from the secondary coil.
