loading
rgb led controller using pot trimmers?
making a rgb led controller and can i put a pot trimmer on the r ,g,and b connections to change the color of the led when the trimmer is adjuding)also add  one to the power supply to use as a dimmer?)imm 14 so i need someone to be specific{like how to wire,parts list(cheap ones please) and etc.)(i have no parent help wat so ever) (im using mulitple leds(about 500) how would i wire them up to work with one controller? and no i dnt want to buy one if i did u would not be asking this uestion
frollard5 years ago
Depends if you want to use high power leds, or just small 20mA leds (5mm rgb)...
Reason being, you can run a small led on a potentionmeter and not really hurt it, because you're only burning off a few volts at 20mA.
If you are driving high power (>100mA) leds then it gets a LOT more complicated, and the amount of power the pot has to burn off is too much - and will cause heating and failure.
Best way:
555 timer pwm driver -- pot controls pwm duty cycle and varies the power to the led. You have to use a transistor to switch the led(s) on and off because a 555 can only handle a few mA of current.
SO
author; What EXACTLY do you want to make? There are plenty of instructables on what I suspect you want - but I'm not going to reinvent the wheel unless you know what you want!
PWM that way doesn't eliminate the requirement for current limiting resistors though
Agreed -- my answer is super simplified until a design goal can be established - then a 'best solution' can be fleshed out :)
Why go analog when its much easier to go digital. Check out my 6 Button RGB Controller. You get 2 buttons per color so  you can adjust the intensity of each color as needed.
