rubber bands; Stretchy not stretchy?
Assuming we are using the same amount of both, is it better to use small rubber bands that stretch to there fullest on the length of the gun or thick rubber bands that stretch over the full length of the gun?
Jan 29, 2009. 12:35 PM=SMART= says:
With smaller ones you will get more distance and power as they will be fully stretched and have more energy stored
Jul 30, 2009. 9:11 AMNYPA says:
don't forget strength. smaller bands will break easier.
May 17, 2009. 10:58 PMfinfan7 says:
Small ones stretch farther and a certain number of them are as powerful as a big one which means that they have the same strength but with more distance to apply the force (accelerate). Small rubber bands in larger numbers also add redundancy; if one breaks there is minimal loss of force.
May 15, 2009. 8:16 PMgeodez says:
you need long-ish and very stretchy for the magazine pusher for less friction and i would suggest thick and short like #64 rubber bands
Apr 12, 2009. 12:54 PMTHESTU says:
Smaller ones
Apr 3, 2009. 9:38 AMMasterCommander says:
Small ones can be slowly stretched larger if too small... small elastics are best
Mar 7, 2009. 6:51 AM6uo4b says:
Larger, thinner ones give accuracy, while short ones provide brute force.
Jan 29, 2009. 12:56 PMajleece says:
one large or few small. adding more large increases the power by heaps but if you add a small the power icreases slowly so you can fine tune
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
