loading
rudder pedals?
What is the best way to make rudder pedals for flightgear with and arduino.
I want something like what on this page
http://www.simprojects.nl/rudder_pedals.htm
or this page
http://www.simprojects.nl/rudder_pedals_iv.htm
If anyone has a good circuit diagram and code that would be helpful.
I took the mixture lever off of my ch products flight sim yoke, added a servo extension between the pot and the main board, and made my own rudder pedals from plywood. works well, and all I had to buy was a $1.50 servo extension and $3 of plywood.
rickharris4 years ago
back to my original suggestion - Use an existing USB joystick that has a rudder axis
Strip it out and remount the rudder pot on your pedals. Quick and easy and not all that expensive.
With open source software you can of course tap into the code but that required knowledge of programming - Do you have that skill?
neeley (author)  rickharris4 years ago
I can program in some languages
Then all you need to do is follow the guide lines for flight gear
thanks
What flight sim are you running?
In many ways the best option is to buy a joy stick that has rudder control and then modify that to operate from a foot peddle. There are many options on the web for making the mechanics of rudders.
Personally I have not had much success with trying to access FSX directly .
http://www.flightsim.com/vbfs/content.php?2007
Is pretty complete
i am using flightgear 2.6.0
