sanding wood?
How do I know which grit sandpaper I should use when i'm painting or sanding a project? When should I use nails or screws so they can be hidden, especially when staining? Also, how fast/slow should i go when sanding?
mikeasaurus7 months ago
This class has you covered!
Sanding is covered extensively in the Sanding Lesson. Your question about hiding screws may be solved with using a countersink, which is discussed in the Drilling Perfect Holes Lesson.
