skateboard bearing lubrication?
9
answers
Answer it!
5 weight is more like kerosene than grease.
The "load" on a skateboard is not much of a load at all, and when I could still ride one it was basically a mode of transport. We rode all day with no ill effect.
White lithium is clean, has the correct consistency, is safe for most plastics and is easy to use. I always keep a tube around my shop and use it to lube the bearings in my shop tools, the garage door opener, bicycle chain and most anything else that requires a light duty, moderate heat resistant gear lube.
Don't use WD-40 or oil as its too light and is pretty much only good for 'cleaning' the bearing.
I found that even using the smallest amount of grease would provide drag on the wheels ( that is when they were spun by hand while holding the board upside down to see who's wheels would spin the longest) but no noticeable difference when actually skating.
I may have been kidding myself back then, but using kero caused no problems, and the wheels would spin for ages.
Any modern day skaters out there have a better option?
