small and quiet air compressor for a single pipe organ pipe?
I've got a 2m long pipe (that I can blow with my lungs). I want to make it into a doorbell but don't have a compressor.
I tried a car horn compressor but it is so loud that it totally drowns out the pipe!
Any other ideas?
dwyan3 years ago
Hey I've seen this befor but how did you get ahold of the plans from the December edition of popular mechanics I've been trying to get a hold of it?
How about a bellows...
Here is mine..
Still have some fine tuning to do.
Do you have directions on how to build this?
Yes...
Here you go.
Enjoy, and post some finished pictures.
Mine still needs tuning...
As the weather changes, so does the tuning...
http://books.google.com/books?id=-9kDAAAAMBAJ&pg=PA102&dq=calliope+mechanics&hl=en&sa=X&ei=U5eTUcaCNMTYyQHYx4GIDA&ved=0CDcQ6AEwAA#v=onepage&q=calliope%20mechanics&f=false
THANK YOU YOU ARE THE BEST!!!!!!! :D i just hope im as talented with mechanics to do it!!!!!!!!! IM JUST SO :D Yay! Thank you!!! If i end up doing it, i will try to post it for you!!!
Lots o work, good luck!
matthewvenn (author) 5 years ago
Thanks all! I used compressed air can in the end, enjoy the video!
http://www.youtube.com/watch?v=70fWGE0hydo
rickharris6 years ago
Get a large can - Put inside the bladder from a football. Between the bladder and the can put a home made pressure switch as in diagram.
matthewvenn (author)  rickharris6 years ago
one thing I forgot to make clear was that I want to use this as a doorbell, so a relatively 'once off' thing could work. It doesn't matter if the tube can only make a sound once a minute or whatever.
Use an aerosol compressed air can - through a pressure reducer to lower the volume a bit. Setting it off might be a problem though.
matthewvenn (author)  rickharris5 years ago
This is what I've gone for, it works pretty well; the only problem is that the can will need to be replaced every now and then, and that the sound of the hiss from the can is audible.
had a different thought - A weighted bicycle pump where the bell push releases the weight so pumping a blast of air through the pipe (may need bellows to get volume rather than a pump ).
A motor can lift the weight to re-set the alarm.
About the Bellows...
Make it like this:
http://www.ebay.com/itm/Train-whistle-6-chime-sounds-like-steam-train-realistic-/120756518712?pt=LH_DefaultDomain_0&hash=item1c1da63f38
(this is not my ad, just using as a example)
lemonie6 years ago
iceng6 years ago
Try a squirrel cage fan they are relatively quiet. . . . . .  A
Use a storage tank, and a very small compressor. Discharge the tank through a nice fat piloted air valve.
Steve
matthewvenn (author)  steveastrouk6 years ago
like a car tyre compressor? I'd probably need a pressure sensor then for the storage tank as well right? So I turn on the compressor when pressure is too low and then off again when it's high enough.
Matt
That's the kind of thing I was thinking of. You could do your own, but you need special on/off switch - I'd contemplate buying somehting from Machine Mart or off Ebay.
Steve
