soldring question. can i solder steel to aluminium?
is it possible to solder a round 8 mm aluminium tube to a 1,5mm steel plate. i tried using glue but did not holde...?
see picture,. are there some weld that may woork??
Mar 25, 2011. 7:06 AMiPodGuy says:
JB Weld
Mar 22, 2011. 11:47 AMsteveastrouk says:
I can't confirm it, but alumiweld rods might work
Mar 23, 2011. 6:36 PMJack A Lopez says:
That's a brand name, right? Alumiweld(r)? I think that's the stuff shown, and referred to, in this instructable:
http://www.instructables.com/id/Quick-and-easy-brazing-aluminum-copper-and-nonfer/
Mar 24, 2011. 2:37 AMsteveastrouk says:
Yes, that's where I saw it. I've seen folks rave about it.
Mar 22, 2011. 1:29 PMVyger says:
Run screws up through the bottom of the plate. You can thread the aluminum tube so it will get some grip if its thick enough or just use a nut and washers. Once you get it started reach inside the tube with vise grips and clamp the nut and tighten the bolt from the bottom plate. You can counter sink the bottom plate and use flat head bolts so it will be flush with the bottom. A Mechanical connection is almost always better than glue.
Mar 22, 2011. 11:28 AMmightywombat says:
As far as soldering goes, no. Soldering or welding aluminum to aluminum is tricky enough by itself. Soldering or welding aluminum to steel will be extremely difficult if not completely impossible. I would recommend either finding a substitute for your aluminum part in steel, in which case you might be able to weld the joint. Alternately, you could try some kind of mechanical connection like roberts our screws. Another alternative would be to replace one of the parts with plastic and use epoxy. Just be sure to roughen the faces of both joined surfaces and make sure there's no oil or dirt on them, otherwise the glue won't stick properly. Finally, you might try the glue that comes in rear view mirror repair kits, which is designed to sick metal to glass. You can find them at auto parts stores.
Good luck!
Mar 22, 2011. 10:28 AMrickharris says:
No. Ordinary lead or non leaded electronic or plumbers solder will not solder aluminium. There are various ways to fix aluminium watch this
However it isn't as easy as it looks. The correct glue is more likely your best bet.  Epoxy resin glue.
Mar 22, 2011. 10:28 AMfrollard says:
Short answer, no. The solders/brazing rods/welding techniques that work for either aluminum or steel are incompatible.
I would recommend epoxy, either epoxy putty, or 2 part liquid. If both surfaces are clean, dry, and roughened up, epoxy will have no problem adhering to both.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
