solid state relay information
Do I need to apply voltage to pin 5 for it to switch on chip Vishay VO14642AABTR?
http://www.alldatasheet.com/datasheet-pdf/pdf/443188/VISHAY/VO14642AABTR.html
steveastrouk says: Nov 15, 2012. 1:30 AM
No, to switch the device, turn on the LED on pin 1 and 2.
Its just like any LED, it needs a current limiting resistor.
Pin 5 is an OUTPUT !
jbaker22 (author) in reply to steveastroukNov 16, 2012. 1:12 PM
What is pin 4 then?
steveastrouk in reply to jbaker22Nov 16, 2012. 1:30 PM
Part of the output circuit. The datasheet clearly shows how it should be wired.
jbaker22 (author) in reply to steveastroukNov 16, 2012. 6:50 PM
So, I would not need it for DC purposes?
steveastrouk in reply to jbaker22Nov 17, 2012. 2:50 AM
Look at the circuits that Iceng posted !!! Pin 4 IS used as part of the output in DC cases. Its linked to pin 6.
jbaker22 (author) in reply to steveastroukNov 18, 2012. 3:35 PM
Hope it will work out like this. https://www.circuitlab.com/circuit/99eua9/rc/
steveastrouk says: Nov 18, 2012. 3:44 PM
You have the battery in the wrong way round for the device. Pin 6 should be connected to the positive supply. Pin 4 should connect to pin 6, and pin 5 to the motor, and the motor to the battery -ve terminal.
jbaker22 (author) in reply to steveastroukNov 19, 2012. 12:09 PM
Thanks, I swapped it around and saved what I think you meant.
steveastrouk in reply to jbaker22Nov 19, 2012. 1:04 PM
CONNECT PIN 4 to PIN 6
jbaker22 (author) in reply to steveastroukNov 19, 2012. 2:43 PM
Okay
steveastrouk in reply to jbaker22Nov 19, 2012. 4:25 PM
You got it
steveastrouk in reply to steveastroukNov 19, 2012. 4:26 PM
WHOA. Add a nice big diode across the motor ! Put the band end aWAY from the battery.
iceng says: Nov 14, 2012. 10:14 PM
You need to understand MOSFETS have Intrinsic Parallel Diodes
See my picture.
A
iceng in reply to icengNov 14, 2012. 10:22 PM
But even though they are as fast as the MOSFET,  I would put a pair
of 1N4006 in parallel in the AC/DC configuration which is half the
current of the plain DC configuration where both fets are in parallel.
A
steveastrouk says: Nov 14, 2012. 4:00 PM
Link doesn't work. Post the device number.
jbaker22 (author) in reply to steveastroukNov 14, 2012. 5:55 PM
I just edited it, sorry.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
