the motor driver L293D controlling the direction of motor, i want to use limit switch to control two position of motor
I am developing a automatic gate project. I want the DC motor stopped as soon as the gate closed or opened completely. I use IC L293D to control the motor forward or backward. This project is also using Arduino. I plan to use a limit switch to control the movement of  DC motor.
Picture of the motor driver L293D controlling the direction of motor, i want to use limit switch to control two position of motor
iceng2 years ago
Just to demo the other way, or maybe to prevent motor stall burn out when the micro goes to La-la land ! .
FarhanJ (author)  iceng2 years ago
thanks a lot! it works...I've simulated the circuit, but the motor can only rotate in one direction and not in the other direction. after changing direction diode then I can drive the motor in two directions, and limit-switch works as well as I wanted.
iceng FarhanJ2 years ago
You are correct !
Please tell me, what is the name of your simulation software.
L293D-1open.JPGL293D-2open.JPGL293D-3close.JPGL293D-4close.JPGL293D-5close.JPGL293D-6close.JPGL293D-7open.JPG
im using Proteus 8
FarhanJ (author) 2 years ago
the simple simulation circuit i made
rickharris2 years ago
Feed limit switches into digital inputs on Arduino.
Then use software to control the barrier.
From your diagram if pin 2 is high and pin 7 low the motor turns 1 way - if pin 2 is low and Pin 7 high it turns the other way.
if pin 2 and 7 are both high or low the motor stops.
FarhanJ (author)  rickharris2 years ago
thanks a lot sir. very helpful idea! ☺
