transponder reader?
I need a small reader built to read the chips we use for cycling.
Jul 28, 2011. 10:46 AMJack A Lopez says:
I found some chatter on this topic here:
http://rfidtoys.net/forum/forum_posts.asp?TID=774&PID=4220&title=rfid-race-timing-hey-amal-i-have-questions
By the way, I think the acronym "RFID" might be more descriptive of the gizmos you are looking for.  After all, in this application the RFID chip does not transpond much, just its unique number and the fact that it is within range of the reader.  Supposedly there are some kinds of RFID tags that can actually respond with variable data, like from a temperature sensor for example, but those kinds are necessarily more complicated and presumably more expensive.
On the subject of cost there are placed to find inexpensive RFID tags and readers, if the gizmo you seek is just  an ordinary, run-of-the-mill RFID tag. That is I am guessing you want to save expense, and/or gain knowledge, by doing some of the development  yourself.
Anyway, there a number of instructables here that make use of RFID, here:
http://www.instructables.com/tag/?sort=none&limit%3Atype%3Aid=on&q=rfid
Jul 28, 2011. 7:45 AMrickharris says:
No where near enough information PLEASE read this
Jul 28, 2011. 8:42 AMsteveastrouk says:
+1
Jul 28, 2011. 9:47 AMsteveastrouk says:
Does it HAVE to be this manufacturer, or are you open to other ideas ? Also, where in the world are you - country is good enough - so we can suggest where to get bits and pieces from.
Steve
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
