tv out arduino code stops?
I recently wrote some code for an arduinio to read an encoder and display it via RCA.
Problem is, it sometimes freezes on a blank screen when I'm turning the encoder.
Any ideas why? the code is below.  And yes, I know that the interrupts mess with the signal and it flickers, I want to know why it will stay off whenever the encoder is halfway through a cycle.
#include <TVout.h>
float anaval = 0;
float value01 = 0;
int val = 1;
float value;
float value10;
float value100;
int out;
int r = 0;
float pos = 0;
int rd = 4;
float incr = 0.00078125;
TVout TV;
unsigned char x,y;
char i = 48;
void setup()  {
   pinMode(2, INPUT);
   pinMode(7, INPUT);
   digitalWrite(7, HIGH);
   digitalWrite(2, HIGH);
   attachInterrupt(0, encoderPos, CHANGE);
  x=0;
  y=0;
  TV.begin(_NTSC,128,56); //for devices with only 1k sram(m168) use TV.begin(_NTSC,128,56)
void loop() {
   disp();
// TV.clear_screen();
  //  TV.print_char(4,4,char(value100)+48);
//   TV.print_char(10,4,char(value10)+48);
//   TV.print_char(16,4,char(value)+48);
  //  TV.print_char(22,4,char(value01)+48);
void stringer(){
   value01 = val;
value = val / 10;
value10 = val / 100;
value100 = val / 1000;
value = int(value);//rounds the variables
value10 = int(value10);
value100 = int(value100);
value01 = int(value01);
value01 = value01 - (value * 10);//removes all but the tenths-place digit
value = value - (value10 * 10);
value10 = value10 - (value100 * 10);
void encoderPos(void){ //this is a state machine to determine the direction of the encoder.
//every half-cycle it counts, effectively doubling the encoder resolution.
  r = 1;
   disp();
  if(digitalRead(2) == HIGH){
   if(digitalRead(7) == LOW){
     while(r == 1){
      disp();
       if(digitalRead(2) == LOW){
         r = 0;
       } else {
         if(digitalRead(7) == HIGH){
           pos = pos + incr;
           r = 0;
   else {
     while(r == 1){
          disp();
         r = 0;
       } else {
           pos = pos - incr;
           r = 0;
}else{//same as the above code, but with High-Low reversed.
  r = 1;
     while(r == 1){
      disp();
         r = 0;
       } else {
           pos = pos + incr;
           r = 0;
   else {
     while(r == 1){
        disp();
         r = 0;
       } else {
           pos = pos - incr;
           r = 0;
void disp(){
  val = int(pos * 1000);
//  TV.delay_frame(1);
      stringer();
You should NEVER put while loops in interrupt routines - the interrupts is holding the whole processor to ransom as it waits.
jduffy54 (author)  steveastrouk4 years ago
Unfortunately, I couldn't find any other way to do it. Do you know where I can find the code for an encoder (the one on this site is incredibly glitchy), that doesn't use while statements? Or is there a way to make a sort of interrupt-statement (when x do y, but in the mean time, run the rest of the loop). I'm using an UNO, so I only have two interrupt pins, but I do need the other for the other half of this project, which I cannot work around (at least, not any way I can see).
Look at edge-triggered interrupts here. Time polling is not the way to go. Even simpler is to use a flip-flop to do direction sensing.
Depending on the exact microcontroller used it the arduino, you can probably set up the pin change interrupts on a couple of the spare pins to pick up the encoder signals. This should work the same as the dedicated interrupts, but just requires a few more lines of code to check which pin changed
