usb heater?
okay so my plan is to build a usb heater for the contest, so it can heat up coffe, hot chocolate, of tea. i am wondering if there is another way of building this than to use a cpu and resistors.
any information will help.
thanks!
Jun 4, 2010. 12:26 PMRe-design says:
Use a resistance coil build out of nichrome wire. You'll have to figure out the length that will draw 100 ma. at 5 volts, which is the most that is safe to draw from a usb unless you design it per usb specs.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
