want to add led "STRIP" lights(30 leds total) as running lights and then brighter for brake lights on motorcycle?
Bought a set of 26" side illuminating red led strips and cut them down to two with 9 leds and two with 6 leds (not really important) as all will be wired into the same connections.
What i would like to do is have them all on as running lights and then come on even brighter once the brake switch/pedal is used.
I have seen some of the other posts concerning this but feel that they do not deal with strip lights, but individual leds.
Thanks for any help.
The strips are probably designed to run on 12V. Run them on a regulator and say 10V normally, then switch out the regulator when the brakes are pressed and put them on 12V
DIYer fox (author)  steveastrouk4 years ago
not that knowledgeable with the details of regulators/switches,can you provide precise details of regulator #s and switches.
should prob add that lights are a two wire design and are 12v
