we dont have 5v on usb after shutdown, why are we trying to power it from psu if psu has no powerout after shutdown?
we dont want power on usb port after shutdown we connect it via molex molex after shutdown doesn't have power too? if we dont want to supply 5vdc from usb after shutdown, why are we connecting it to PSU which doesn't supply 5vdc after shutdown either?
lizbryant885 years ago
Usted necesita las gafas de sol Ray Ban que caen con facilidad, pero que definitivamente no salen ray ban aviator rápidamente. Realmente es natural para el bebé que se quejan de un cierto número de estanqueidad cuando Ray Suspender las gafas de sol primero usar este marco.
andy7 years ago
You can pull 5 volts off the purple wire (if you have one). The mother board uses this to detect when the on button has been pressed, but a moderate current draw in addition may be tolerable. The purple wire should supply approximately 5v at 200 mA whenever the PSU is plugged into the wall.
I suggest you research the feasibility of tapping into this supply wire, normally called the "+5 volt standby" wire.
Andy
Re-design8 years ago
Some powersupplies will have power to usb even on shutdown. I like to charge my mp3 while the computer is off.
kevinhannan8 years ago
I think you've kind of answered you own question; It wouldn't be shut down if there was power out, now, would there? That would apply to molex and all the other power rails. Do what Kiteman says: if you need power after shut down, what is it you're trying to do?
Kiteman8 years ago
If this question relates to a specific Instructable, you ought to post in in the comments of that instructable, or send a PM to the author.
