well i ran into a little problem yesterday with my flash drive?
the HP website does not provide this specific flash drive ,driver for the drive
i need this flash drive for school to store my essays on so get to me ASAP
thanks.
PS. i spent my allowance on the thing so i want to get the most out of it
10
answers
Answer it!
L
www.datarescue.com/photorescue/v3/try.htm
If you want to recover stuff you'll have to get a registration key, but the repair bits will work without.
L
A reformat may work to make it functional again, although the odds of that are 50%. If you can't reformat, buy a new one.
To prevent this in the future, either eject it like you know you should have in the first place or disable write-caching for this drive in Windows. Disabling write-caching will slow the performance a little, but will allow you to yank it with less worry.
Given that you can get a 4G unit for under $15 these days, I'd say that if a hard format doesn't solve your problem, chuck it and replace it.
Open "My Computer." Click on "Manage" in the "Explorer" window of "My Computer."
- Open the "Device Manager" and locate your USBDrive installed under the "Disk Drives" tab. Right click on "Removable Disk Drive" and click on "Properties" from the menu.
- Click on the "Policies" tab and choose "Optimize for Performance" from the options. Click "OK" and continue.
- Click on "My Computer" and choose the format on the flash drive.
- Choose "NTFS" or "FAT32" depending on the type you want from the dropdown menu box.
- Click "OK" to complete the format.
Oddly I've found that even corrupted files usually just crash the opening program, so it's either bad luck or something serious. If the computer recognizes the device but can't open the root folder try right clicking and choosing the explore option, sometimes that'll by pass the problem, in which case you can try to wipe out the problem files and recover your own.
If you can't get the drive to work again you can use any storage device, your phone, your digital camera as a stopgap measure or even email your work to yourself.
