wemos d1 mini blynk? display temperature&humidity?
this is my code and it works to display c&% on display and blynk app and it notifies me when it starts and run time, is there a way to display runtime/uptime on the display and should i remove anything? maybe add in code to send email when offline for more than 5 minutes?
why does the screen go black when it updates?
what other data can i display on the screen? it will be used to monitor server room temperature, thanks
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include "Adafruit_SSD1306.h"
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
#include <DHT.h>
#define OLED_RESET 0  // GPIO0
Adafruit_SSD1306 display(OLED_RESET);
#define BLYNK_PRINT Serial
#define DHTPIN D4
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "";
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "";
char pass[] = "";
BlynkTimer timer;
void notifyUptime()
  long uptime = millis() / 60000L;
  // Actually send the message.
  // Note:
  //   We allow 1 notification per 15 seconds for now.
  Blynk.notify(String("Running for ") + uptime + " minutes.");
void sendSensor()
  float h = dht.readHumidity();
  float t = dht.readTemperature(); // or dht.readTemperature(true) for Fahrenheit
  if (isnan(h) || isnan(t)) {
    Serial.println("where is my DHT sensor!");
    return;
  // You can send any value at any time.
  // Please don't send more that 10 values per second.
  Blynk.virtualWrite(V5, h);
  Blynk.virtualWrite(V6, t);
void setup()
  // Debug console
  Serial.begin(9600);
  Blynk.begin(auth, ssid, pass);
  // You can also specify server:
  //Blynk.begin(auth, ssid, pass, "blynk-cloud.com", 8442);
  //Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,100), 8442);
  dht.begin();
// Notify immediately on startup
  Blynk.notify("Device started");
  // Setup a function to be called every minute
  timer.setInterval(60000L, notifyUptime);
  // Setup a function to be called every second
  timer.setInterval(1000L, sendSensor);
void loop()
  Blynk.run();
  timer.run();
  Serial.begin(115200);
  dht.begin();
  // by default, we'll generate the high voltage from the 3.3v line internally! (neat!)
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C);  // initialize with the I2C addr 0x3C (for the 64x48)
  display.display();
  delay(5000);
  // Efface l'écran et positionne le curseur dans le coin supérieur gauche - clear display and set cursor on the top left corner
  display.clearDisplay();
  display.setTextSize(2);
  display.setTextColor(WHITE);
  display.setCursor(0,0);
  float f = dht.readTemperature(true);
  float bat = ESP.getVcc();// / 1024;
  // Check if any reads failed and exit early (to try again).
  if (isnan(h) || isnan(t) || isnan(f)) {
    Serial.println("where is DHT sensor!");
    return;
  // Température en Celcius - Temperature in Celcius
// display.println("Temp.");
  display.print(t);
  display.println(" c");
  // Humidité en % - Humidity in %
// display.println("Humidity");
//display.setTextSize(1);
  display.print(h);
  display.print(" %");
  display.display();
