loading
what are the different grades of helium?
how do the different grades affect lift capacity?
Lifting ability depends on the difference in density between the lifting gas and the atmosphere gas.
For example, suppose you've got a V sized balloon of some gas.  There's an upward buoyant force equal the weight of the air displaced, and there's a downward force equal to the weight of the lifting gas.
ΣF   =       ρatm*g*V - ρlift*g*V
ΣF   =       g*V(ρatm - ρlift)
You can simplify this further by assuming that both the lifting gas and the atmosphere gas, are ideal gasses at the same temperature, so that they have the same mol density (P/R*T) = (1 mol/22.4 L).  The trick here is that now calculate that lifting force just based on a difference in molecular weights.
(ΣF)/(g*V) = (P/R*T)*(matm - mlift)
                = (1 mol/22.4 L)*(14.4g/mol - mlift
Then you can use that formula to make a little table for some of your popular lifting gasses.
gas,    mol weight,  lifting ability,  relative to vacuum
vacuum,   m=0,        0.64286 g/L,    1.000,
H2,         m=2,        0.55357 g/L,    0.861,
He-3,     m=3,         0.50893 g/L,    0.792,
He-4,     m=4,        0.46429 g/L,    0.722,
Here I am assuming the most bad-ass lifting gas possible would be a super-engineered (magical really) balloon that could somehow hold vacuum without collapsing. Or maybe its a magic photon gas or something. You know: it exerts pressure, but doesn't have any weight.
So as you can see from the table, helium-3 is a little bit better lifting gas than helium-4, but molecular hydrogen (H2), is a little bit better than both of those.
The trouble with helium-3 though, is that its really expensive.  They have to mine it on the Moon, because it is not abundant on Earth.  I think its used in some fusion reactors, and you can look into that, but I expect isotopically pure He-3 will be very hard to find.
That's why I recommend using H2.  It's cheaper than both 'topes of helium, and you can make it yourself from tap water.
https://www.instructables.com/pages/search/search.jsp?q=make+hydrogen
Uh... wait a minute. It looks like was using the using the wrong number for the average molecular weight of air. It's N2 and O2. So I should have used matm=28.8 g/mol, and that changes that whole table:
vacuum,   m=0,    1.2857 g/L,     1.000,
H2,            m=2,    1.1964 g/L,     0.931,
He-3,        m=3,    1.1518 g/L,     0.896,
He-4,        m=4,    1.1071 g/L,     0.861,
Sorry, 'bout that.  But the trend's still the same.  H2 is a little  better lifter than He-3, and He-3 is a little better lifter than He-4.
Re-design5 years ago
The different grades are undetectable by comparing lift unless in extreme laboratory tests.
iceng Re-design5 years ago
I did some EE work for a client that had an indoor 2' round blimp powered by a
3D fan drive in a game and now I remember he found that higher purity of
helium kept his blimp operatable two days longer then balloon helium.
verence iceng5 years ago
Which does mean nothing until you tell us, how long it operated on balloon helium (e.g. 100 days vs. 102 days - who cares, 0.1 days vs. 2.1 days - now that's something!) ;-)
iceng verence5 years ago
Sorry, 2 days with balloon He to 4 days on higher purity ( only know higher ).
This blimp tried to achieve neutral buoyancy by tiny weights.
Operating days were when removing all provided weights failed.
( don't know weight ).
A
iceng5 years ago
I found this on helium grades.
A
