what battery pack would be needed to run these LED light strip for 6 hours?
Hi all,
I am looking at building a wearable battery pack to power these light strips,
As I am looking at this the wattage seems high 12 watts, I figure 8 AA 1.5 VDC batteries run in seriers would do the trick but any idea on run time?   http://www.dealextreme.com/p/12w-470nm-150x3528-smd-led-waterproof-flexible-blue-light-strip-5m-length-dc-12v-96072
Thanks!
Jul 15, 2012. 12:53 PMsteveastrouk says:
BTW, BIG AA batteries hold a maximim of about 2.8 Ah - that would give you 2.8 hours of running on your LEDs.
Jul 15, 2012. 1:07 PMfrollard says:
+1
Those led strips are uncomfortably bright in many scenarios - so you can actually stretch their runtime with a pwm circuit - just a 555 timer and a big transistor can act as a dimmer and efficiently save lots of juice!
I'm a big fan of using AA or C/D cells for this type of thing.
Lastly, those strips should light with as little as 5 or 6 AA batteries.
Jul 15, 2012. 12:31 PMsteveastrouk says:
Use a sealed lead acid battery. You'd only need a 6Ah battery.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
