what can I do with a big sheet of fresnel magnifier plexiglass?
my neighbor through out his old rear-projection television, and I salvaged the pane of plexiglass with ridges in concentric circles used to magnify? or focus? the image. I am sure I could figure out how to solar heat something with it.. but I thought you all would like to know that I am open to suggestions.
so far, the boy and I have done the very obvious.. burn the lawn, burn paper, and boil water.. all in the late afternoon sun. At midday, that thing will be instantaneously hot.. I think I could weld with it!
hey, thanks for the heads up on retina protection.. your a little late though. It was not as bad as an arc, or magnesium, or an eclipse, but it was worse than a 100 watt bulb. we realized it was damage after the first test, and we are all safe now.
Solar ovens are the way many use them. Can be used to power a Stirling engine quite effectively. Or just use it to be an "artist" and give momma earth a tattoo.
Bio:I am a 41 year old misfit and the father of one magnificent boy. I got a degree in '99, but my chosen field is barely more than a fond memory. I am interested in anything that will keep my son's inter...read more »
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
When you think about condensing a 3x5 panel (~15sqft) area of sunlight down to a 1/2" dia focal point, the energy density is nice and juicy.
Roughly speaking, an energy multiplier (at the working end) of well over 3000
Well there you go. Make yourself a solar furnace for melting down beer and pop cans. Then you can sell the ingots.
"Fry" a giant-ant?
L
www.solarcooker-at-cantinawest.com/fresnel-lens-solar-grill.html
