what can i do with this old tablet screen?
i have salvaged an old lcd screen from a velocity micro cruz t301. it has a 60 pin ribbon cable connector. is there any way i can use this to connect it to rca cables?
Yes get the data sheet and you can even connect it to Arduino.
You need to match the + and – volts data inputs clock and other things.
They all basically work the same way it is just the connections you need to work out.
Joe
Is it possible to connect a R Pi3 to the old tablet which is dead?
You can use kits like these to test and convert all kinds of screens.
https://www.banggood.com/7-84inch-LVDS-Screen-LCD-...
reggie88980 (author)  Josehf Murchison4 years ago
Okay where can I find the data sheet?
Short answer... No!
+1
rickharris4 years ago
Because the screen needs a video driver - If you don't have that you will need to design and make one, more than likely involving a microprocessor and some programming.
usually this isn't really very practical.
Getting the screen is the easy bit. IF they were easy to use you would find project all over the place to re use them for many things. BUT there isn't - for a very good reason.
You can Google “LCD datasheet 7" 800x480” and it will send you to pages like this one,
http://www.alldatasheet.com/datasheet-pdf/pdf/473433/HANTRONIX/HDA700L-GH.html
Or you can look on the back and get the part number.
Then go to this web site, and search the part number.
This is another web site I like for data sheets.
http://www.maxim4u.com/
Joe
