3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
what determines the max current that can be drawn from a transformer's secondary coil?
how could i figure out what the max current i can get out of a transformers secondary coil? example: a welding transformer
Nov 21, 2009. 9:55 PMseandogue says:
V2 = V1*N2/N1, where Nx is the number of windings, N1 primary, N2 secondary. (in absense of losses), and
I2 = I1*N1/N2
Yes, roughly speaking the input side current can be calculated as
I1 = V1/R(primary)
technically these are inductors, so R is actually frequency and inductance dependant and the numbers change a little, but for the sake of brevity...
That will give you a ballpark idea. The efficiency of the transformer is unknown, so the actual output will be somewhat lower than the calculation.
I'm not such a fan of calculating unless someone else has already put a device thru the empirical hoops and would prefer measuring the input side current, but whatever...
regarding the ga of the output wiring, that pretty much determines the maximum current that can be delivered no matter what, as it will heat up and melt if it goes beyond its capacity. (and it's why I included it in the note above, due to the nature of your original question title.)
Nov 22, 2009. 1:01 AMlemonie says:
These are inductors - you can't get meaningful values of inductance / impedence by measuring resistance.
If you want heavy-current you'll need a big heavy transformer (in the foot-crushing range of "heavy")
L
Nov 22, 2009. 4:41 AMseandogue says:
Yeah, sorry, wasn't thinking re: input side. contact the transformer mfg for the specs on it's performance. Guessing won't do.
Nov 22, 2009. 8:59 AMlemonie says:
You'd still need quite a large transformer to handle 30amps, your reference to overheating in the secondary is appropriate.
L
Nov 22, 2009. 5:42 AMNachoMahma says:
.  Figure out what gauge/gage wire you have. Strip the (enamel) insulation and measure with a dial caliper or similar. Compare measurement to an AWG table.
.  Look up ampacity for that gauge wire. May get lucky and find that figure on same page as above.
.  This will give you a ballpark figure.
Nov 21, 2009. 8:34 PMseandogue says:
The primary side voltage and current, the efficiency of the transformer, and the secondary winding ratio and wire gauge
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
