loading
what does half a red ring round the power button on my xbox 360 mean?
if you are trying to fix red light of death on your own i recommend you to visit this blog at xbox ring of death fix in under 40 minutes
mweston7 years ago
lemonie7 years ago
This is a common problem caused by Xboxes being craply-built/designed.
There are a lot of fixes on this site, under the title "Red Ring of Death". Half of one should feature somewhere, but this is what the official line is (overheat):
http://support.xbox.com/support/en/us/nxe/kb.aspx?ID=907533&lcid=1033&category=hardware
L
nickodemus7 years ago
Apparently it's an overheating problem
THINGS TO TRY
  1. Let the Xbox 360 console cool.
    Note You may have to wait several hours for the console to cool enough. Do not turn on the console when the console is hot.
  2. Verify that the console has sufficient ventilation and that the fan is operating. For more information about ventilation, see the "More Information" section.
PREVENTION SUGGESTIONS
To try to prevent this problem, use the following precautions:
  • Do not block any ventilation openings on the Xbox 360 console.
  • Do not put the Xbox 360 console on a bed, on a sofa, or on any other soft surface that may block ventilation openings.
  • Do not put the Xbox 360 console in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well-ventilated.
  • Do not put the Xbox 360 console near any heat source, such as a radiator, a heat register, a stove, or an amplifier.
Source: Llamma.com
I'd suggest reading up on that link before you try anything radical, like putting it in a freezer. (BTW, don't ever try that.)
zascecs7 years ago
Your Xbox is half-dead
kcls7 years ago
2 of the lights behind the power button are out?
