what if i use household materials to "carry hydrogen and oxygen on its normal state?
I use electrolysis to separate oxygen (Negative) and hydrogen (positive) from water and store it in a water bottle so that i have a portable system of hydrogen and oxygen so that i can use it a few minutes after its "extraction".
Visit Our Store »
Go Pro Today »
I am assuming your water bottle is empty?
Your not going to get much gas without compressing it though - Depends on what you want to do with it.
Thank you for the help :D
Also you avoid storing Hydrogen..
Hydrogen is a single atom which leaks from any pressure container
devised by man.. It Hy is sliding between the empty spaces in the metal cylinder atomic structure used to contain it.......
A
Absolutely no problem at all.
The reason cryogenic storage is used is that oxygen gas at room temperature / pressure will have 848 times the volume of liquid oxygen. For hydrogen it will be 860 times more.
Pressurised storage is also used, but a much greater volume can be stored when in liquid state.
Thank you for your help :D
